All of a sudden about 2 weeks ago my truck started to die when I put it into gear. Here's the whole story. I started modifing my truck just over a year ago. All in one shot I installed a Comp Box, BD XXX injectors, Suncoast convertor (don't know the model #:{ ), BD valve body, AFE, exhaust, and a 7psi pusher pump. Truck was awesome for about a month and then it started to die when I would put it in DRIVE. I needed to drive it so I worked with it, well about a week later I forgot about the whole issue and went to put it in DRIVE one morning and it took me a minute to realize that I didn't have to do anything to keep it from dying.
After that it would NEVER die going into gear, although it still engaged hard due to the convertor. Truck was great up until 2 weeks ago. It started to do the same thing, it would die when I would put it into gear, mainly only in DRIVE sometimes in REVERSE.
Needless to say I'm baffled. I've changed transmission fluid, checked transmission pressures on passenger side port, disconnected my box, disconnected my pusher pump, changed injectors, and I nothing has helped.
DOES ANYONE HAVE ANY IDEAS? I've exhausted all of my options!!! :{
