Truck Has A Start And Dieing Problem
I am having problems I drive my truck about 225 miles a day round trip to and from work. Can't afford to have it down for long. Anyways the other day I was on a location about 105 miles from home. Truck ran great to work, after about 10 hours I started my truck to move it ,started and ran fine,proceeded to b. s. some guys it ran at idle for about 30 min. before I moved it out of the way of our big trucks. Got off work 2 hours later. Started up fine ran for about 20-30 seconds then just died, would not restart... FAST FOWARD...
The next day had determined it was my lift pump at fault. Replaced had a hard time bleeding the air out to get it to restart. I had noticed that the lift pump was making a sound like it was loading up and pumping then the sound would get real weak like it had no fuel to pump. Got running ran fine started home made it about 60 miles, and then it died just as if you had turned the key off. Sent my wife to nearest town to get some fuel, I thought mabe fuel suction had a crack in it. While she was gone me and my son were looking at it. I had him turn the truck over so I could feel if the pump was running. ( to noise just off the hwy. ) Well what do you know I found a short in the pig- tail , wiggle the wires and the pump ran accordilingly. The new pump came with a new pig-tail. Got repaired ran great for a few days. . This morning I stoped at a truck stop , went in for 10 minutes came out started it up ran for about 20-30 seconds and just died again popped the hood wiggled the wires had to bleed the injectors again ran home fine . Need to figure out before it leaves us stranded again. . Thanks all replies or comments welcome.....
TRUCK IS A 01 2500 4X4 QUAD-CAB
