My truck just died, like you shut off the fuel. Was shifting from 2nd to 3rd, and when I let out on the clutch I had no power. Pushed in on the clutch and reved it up, but the motor had died. Will not restart. Checked all the fuses, disconnected the ez and TST power-max 3 fueling box. I have 15 lbs presure at the filter. Cranks over fine, but will not start. I have 12 volts at the VP44. What can it be?
TNT Machine
98. 5, 3500, QC, SLT,5 sp, 4. 10 w/ Ltd Slp, 4x4, Intense Blue, GN hitch, TrlPkg, TowPkg, vacuum pp, EGT gauge, Boost gauge, pre and post filter fuel pres gauge, fiberglass running bds, Power Edge EZ w/boost fooler, TST Pwr Max set on 3, BHAF,Mag-Hytec dif cover,4"exhaust,Eaton PTO trans filter.
TNT Machine
