I have a 99 2500, everything aftermarket has been removed from the truck except the air dog lift pump. Fuel pressure is a constant 13psi when running.
When I start the truck it starts as usual and runs good until it suddenly shuts off just like turning off the key. The truck will not restart unless the batteries are unhooked for a second then it will do the same thing again. If I don't unhook the batteries the lift pump never comes on and the truck never even tries to fire.
This is not entirely a new problem to this truck it has been doing it randomly for about 4 months when the adrenaline would try to ramp the truck up to high idle, however this was the first time it had shut off while driving down the road. I pulled over and removed the adrenaline thinking that was the problem, but there was no change.
I was able to limp about half way home with the truck running less and less at a time until I was unable to drive any more.
I checked the codes and got 3
Po237 I think this may have been caused by the key being on when i unhooked the map sensor wire to remove the adrenaline
p1689 I read that this can be caused by cranking the truck with the fuel system relay pulled which i did loading it on the trailer.
po253 this one says Injection pump fuel metering control a low, cam, rotor, injector I am not sure what this one might mean. I cleared all codes and none of them came back when i restarted the truck two more times.
Thanks for reading my long winded post and hopefully some one out there in tdr land has an idea of where to go from here.
