I would also like to add that whatever is shutting the engine down is also cutting the lift pump also. The engine cuts first then the fuel pressure drops about half a second later. Trying to crank after shutdown the fuel pump will not run and the wait to start light will not cycle. When I unhook the batteries and try again everything works as normal, for about 3 seconds after startup.
Thanks for all the good ideas, I would love for this to be a simple stupid problem that got by me and would be cheap to fix.
Nick
Nick
