On my way home last night after turning into my driveway the truck suddenly stopped running . Now it will not start . If I bump the starter I am getting 0 psi on the fuel pressure gauge although I can still hear the lift pump run . I hooked up an external pressure gauge at the injection pump and it confirms the 0 psi I am reading inside the cab . The fuel gauge is reading about an 1/8 full .
I just replaced the lift pump a month or 2 ago so that may or not be the problem but , I did not think the truck would just stop running if the lift pump suddenly quit . At any rate there are no codes showing . After reading some stuff on here about fuel gauge sending units and there problems is it possible that I just ran out of fuel . I bought another lift pump as a backup and will put that one on but , first I think I am going to put 5 gals of fuel in the tank and see if I get any pressure on the gauge . What do you all think ?
Also if I did run out of fuel what is the best / easiest way to get the truck restarted ?
Thanks in advance for any insight ...
