Truck Weight-Wa. Registration
Allison automatic trans (DMax) is "light duty"
How to test for turbo hose leaks???
Is there a specific weight that registration becomes cheaper? My truck weighs 6,840 pds. Should I make it weigh more? I'm going to try to get in tomorrow.
Wahington Charts for Fees
I am just getting up to speed on this as I considering a big trailer.
Here a Washington State site for truck fees.
Legally your required to register 1-1/2 times your weight empty.
I going to Bump my 2500 from 8000 to 10000 to be safe, or you might be over weight if your ever weighed when you above 8000. your 6500 require a minimum of 8000, next even number. That what mine is register for, but I believe it should be for 10,000 to cover the 8800 actual capacity, or 10,000 at 1. 5 times 6500 = 9750. You could probably justify 12,000 if you wanted.
I ot sure where this put you when your towing, There were huge fines given out in Pennslyania for truck trailer not being licenced for GCVW. Like $1000-$2000 a gig
http://www.dol.wa.gov/vs/GrossWeightChart.pdf
