To start with the truck was running a little rough at an idle and just a little off idle and sometimes in the morning it took a little bit longer than normal to start. Sometimes when it would start it would run really rough for a few seconds and the clear up. So a couple of days ago I replaced the dry rotted fuel lines and replace the fuel filter and the truck hasnt run since then. I realize that doing this that I would get a bunch of air in the system so I cracked the bleeder on the filter housing and the injector lines and still nothing. I even thought I might have crossed the lines(feed and return) when I hooked them up so I switched them a still nothing. Next I removed the fuel heater and replace the gasket and pre-filter. I also replaced the o-ring on the primer button that was leaking. I even tried pressurizing the fuel tank while cranking. I am getting fuel coming out of the bleeder valve on the filter housing. Could I have possible had a lift pump going bad and it just isnt strong enough to prime the system again? Thanks, Kevin
