TSB 18-066-23
Hot weather Aisin limp home mode
G56 clutch replacement
The following improvements are also included in this update:
• **Transmission overheat protection (DG7 Only).**
• Adaptive Cruise improvements at high altitude.
• Ambient Air Pressure displayed correctly in wiTECH.
• Oil pressure switch modification.
• Cold Start improvements.
• Oil change monitor improvement for severe duty operation.
• Engine Warm up Protection Improvement to help promote better oil delivery to engine bearings during cold starts.
• Transmission Overall Shift Schedule Improvements.
• wiTECH “Fuel Injector Cutoff Test” fix. • wiTECH Mass Air Flow (MAF) Sensor data display additional fix.
• Enabling wiTECH Particulate Matter (PM) Sensor Regeneration Test in PCM “Misc Functions”.
• Hydrocarbon Desorption (HCD) Mode operational improvement. HCD mode resumes after key cycle.
• Enabling message in dash alerting operator when in “Exhaust Brake - Cab Warm Up” mode.
• System Improvement for “Exhaust Brake - Cab Warm Up” mode.
• Transmission upshift quality enhancements (68RFE Only).
• wiTECH “Fuel Pressure Override” test improvement.
• wiTECH Mass Air Flow (MAF) data parameter improvement (displaying raw value instead of estimated).
• wiTECH fuel system run-up test improvement.
• wiTECH fan actuation test improvement.
• Smart Exhaust Brake operation improvement.
• Engine warm up protection system improvement. Max engine speed limit change from 1,200 RPM to 1,000 RPM during initial startup in extreme cold ambient temperatures.
• Improved shift quality and engine performance when in 4LO.
• Idle Shutdown Timer System improvement.
Not to bad
Not to bad
It is a list, that’s why I included the link so people could read about it.
What year is your truck? Your sig says you have a 2015 and you posted in the 2010-2018 forum, yet that TSB you linked is for 2019 trucks.
It is a 15 as my signature states. I see why you say that, but when I called to ask about open recalls. This is where I was directed and they had my vin.
Correct, nothing about this TSB applies to a 2015 truck. It’s for 2019 ETM and ETL engines. The 2015 has an ETK.
There also isn’t a software crossover from 13-18 and 19+trucks. The TSB calls out ACC, which wasn’t even an option until 2019. The supplemental cab heater also wasn’t around until 2019.
@rynosback If that’s truly the TSB listed on the invoice I’d be asking the dealer some questions. I’d also ask if the 67A recall was applied, assume nothing.
