tomeygun said:Slow down speed racer... I see you are in EDGE's backyard, right? (Ogden, Utah) - Must be nice, Hot version within minutes
So have you had that truck dynoed yet? PS - I did not know EDGE made a "jucie" :-laf :-laf (I saw it in your sig, sorry couldn't help myself)
Also, Second that on the low-boost fueling, My lord can 5x5 lay some coal!
But the top end does not match the low-boost fueling, Mine seems to fall off a bit...![]()
Already got the got done in about 10 mins you think the low boost is bad in 5 you should have seen when I left edge after getting the hot ver one of my connections was not hooked up right so I would only boost 20 psi with the injectors hooked up right you should have seen the smoke then on level 5 the cars behind me where swerving to see the rd.
And damn I need to fix that sig thanks for pointing that out.
No I have not had it on the dyno yet the only dyno I know around hear is edge and I don't think they do public dynos know except on there dyno days but I'm not going to waite in line for it maybe one day, I know I wount be as much as you cuz I run a stock turbo.
