I got one of the first boxes TST put out. My clutch lasted 1 hr. Also it appears that the 6 spds have much less problems with EGT's than the auto's do.
Originally posted by FastEnough
I really wish AM made a 60psi Phantom gauge![]()
I am still running the EZ elbow. I do have the TST elbow now but I am thinking about putting the stock one back in and seeing if I can adjust the wastgate.
Originally posted by lmills
You can get a 60 psi phantom gauge from autometer. You have to call and special order it. Some other members have done it in the past
Originally posted by Greg Boardman
Diesel Dynamics in Las Vegas has the 60 psi guage. I know I have one... .![]()
Originally posted by HotRam03
So is it safe to say that with the injectors I will exp. an engine knock? Has anyone else experienced this with injectors or Lonestar you the only one?
You could always try one of the hybrid 40/55's. They have a 40 exhaust housing and a 55 compressor. The 40 exhaust housing is easier to spool
Originally posted by SRadke
The box is programmed with a basically linear fuel ramp that levels off at 35 pounds of boost. I don't think you'll be able to maintain 40-45 lbs boost. Anything over 40 psi is off the map for this turbo anyway and will net little gain.
-Scott
Who put those together and sells them.
