Originally posted by HotRam03
Alright I just put my TST PMCR on tonight I have a problem How do you hook your Edge EZ back up????? I want to stack both. I did not install that elbow because I am running DD's Jammer turbo, I dont guess or think I need it. I hit 39 lbs of boost with my current setup before this box is it going to cut the fuel back because of this 35 lbs boost fuel limiting deal???????
Originally posted by Floor It
Agades,
It's an External wasgate that you put into the exhaust manifold. The QSB1 can accommodate a wastegate but you have to flip the manifold over( and use a manifold off an ISB 24v) so the turbo can have one. TheQSB1 will accommodate one, it will hit the block with it in its current location.
John
Originally posted by Agades
The boost slams up to 35psi , then gate opens , boost suddenly drops to 30psi, then slowly climbs back to about 34psi (setting 2x3)
