Originally posted by bpenrod
I would hope for a trade in program as well! I know I bought my VA early and I still am very pleased with it. I am hoping for timing to cool off the EGT on the full setting. In the meantime I was thinking of looking at the Volumizier. If I'm not mistaken it does some timing (although not sure how looking at the connectors in the web pic!) and some pressure. Maybe the timing will help on the EGT's, that and maybe a little water injection... ... ... .....
Well, lets hope for a trade-in program similar to what Edge was talking about for EZ owners wanting to upgrade to Juice.
the volumizer is like the Ramifier in its pressure function, plus it adds a touch of timing (it connects to the cam and the crank sensors). From looking at the HP figures I'm not convinced that there is much timing in the Volumizer. Its strengths are a lot like the Ramifier -- it remaps boost signal (tells the ECM that boost is really higher than it is) so the low end is very strong. Yet, at the top end at high HP / high RPMs, it is on equal footing with the other pressure boxes at the same pressure in terms of its ability to make HP. I'm not yet able to report on what exact pressures these boxes attain, other than what the mfgs say. working on that part...
In my opinion that (strong low end) makes the Volumizer a bad stack with the VA duration box, simply because, like the Ramifier, it is too strong down low, i. e. too much when you stack with the VA. But thats just my opinion -- if you want lots of black smoke you should get it! Indeed, you can make black smoke with just the two VA boxes stacked, so imagine a boost-fooled ECM trying to fuel hard down low
Again, this is my opinion, but it appears that the EZ or Quadzilla or even Bullydog would be a better stack for the VA. they have omplimentary torque curves. that is, a pressure box that isn't so aggressive at the low end, but finishes strong. Ramifier could do that with a custom program. Or off-the-shelf Quadzilla, EZ or bullydog.
If you want to add timing and pressure to the VA duration box, there's always the Banks six gun w/o speed loader. I'm not sure how aggressive the Banks is at the low end. it may be too much as well.
