turbo housing
Diff in HO engines from STD
Fuel Cost
I just saw a add for a ... . 16cm Non-Wastegated Turbine Housing . Can I just put my turbos guts in this housing? If so what kinda egt gain would I get? I have also heard that a wastegate will still open under high pressure with a 22 shell in it. Is that true?
Semerson you are screwed when it comes to changing the housing on a HY35 turbo.
The are no options... ... .....
But the Piers Modified HX35-14 Super&reg Turbo will knock your socks off :D
This Piers&reg Turbo is just <b>Awesome</b>
Check it out www.piersdiesel.com
The HY and HX turbo's use different mounting methods to the exhaust housings :(
