Engine/Transmission (1998.5 - 2002) turbo how will i know when it's going bad
Engine/Transmission (1998.5 - 2002) To Smarty,or not to Smarty??
Engine/Transmission (1994 - 1998) Goerend Torque Converter Which One?
You'll hear a grinding sound sort of like a train chugging down the track followed by a bang after a while. then some smoke and then you will have a bad day. check the inlet for oil and see if there is excessive shaft paly on the compressor. Those are definite signs the turbo is going away.
there is no oil but there is some up and down movement
no movement in and out
but it was tight before it went to cummins for service
now it has slight up and play
I guess as long as there is no oil it not a problem
