Engine/Transmission (1998.5 - 2002) turbo life?
2nd Gen Non-Engine/Transmission front receiver hitch
Engine/Transmission (1998.5 - 2002) fuel filter lid o-ring
With 172,000 miles on my stock turbo I am starting to see some play in the bearing on the intake side of the shaft. I don't have a dial gauge so I don't have any hard numbers but I would say I can move the shaft up and down about 1/32" to 1/16". it feels tight front to back with no toticable end play.
so, considering that it sees 40# of boost from time to time is it just worn out or do you guys think it's ok. I would rather replace it before it gernades and leaves me stuck on the road.
Maybe it's time for a HX 40 and some larger injectors:D :D
thanks
Mike
The impeller shaft fore and aft allowable endplay is MIN . 038mm(. 0015") and MAX . 089 (. 0035").
The allowable radial bearing clearance is MIN . 326mm (. 0128") and MAX . 496mm (. 0195")
These are the specs out of the service manual.
