Hello, I have recently been having turbo issues. It works for a while and then stops. A few days later it is working again. This has happened several times. Is it likely time for a new turbo? If so, what is a reasonably priced solution? 2006 5.9 Cummins with automatic trans with 360K miles.
The problem that I see when it fails is low boost pressure error and it can barely get out of its own way.
I see some new turbos in the $350 or so range (if that is what I need) Are these any good?
Thank you
Thank you
