Details here: TDR Privileges
Has anyone installed a BD Turbo Timer 2 in their first gen? I have everything but the ECM wire hooked up and don't know where to connect it? Any help will be greatly appreciated.
If that is the name for the wire I would say it goes to the injection pump solenoid. If that is the only wire left leave it unhooked. Hook a test light to it. Ground the test light wire. Start the truck and set the timer and see if the test light stays on for the set time of the cool down event. If the test light goes off at the end of the timed event. Then you know for sure it goes to the injection pump solenoid.
