dint want to pollute someone else subject .....
1st gen 12V intercooled Cummins 93 Ram , A518,3:54 gears .....(low milage )
I want to get 300-350HP out of my Cummins ( what are the expected torque figures for these HP )
reason will weight around 9000 lbs when converted into a RV
already ordered some 5 x .012 SAC 145 nozzles from DAP and a 3200 governor spring from DAP ( Jkid) ;-)
already did the mods on the VE pump
yes..I have all the gauges ( EGT, Boost , transmission oïl temp & AFR )
Already changed for a K&N CAI.....
Will change the exhaust for mandrel 4" .....
So , turbo Wise : should I go for HX35W , HX40 or HE351CW ?
I just cant decide myself ........newby to cummins mods ,just cant figure wich would achieve my goals .......at 9000 lbs I want a good running rig that will climb hilly roads without dying ....nothing more.....
thanks for all inputs !
Dan
Dan
