JamesThomas said:It either has to be really cold or it has to sit for around 12 hrs or so unplugged in the low 30's. I haven't plugged mine in once this year amd the coldest it has been was 7*. I got the 3 cyl idle on that day... i
***d6 said:Im sure the feature can be disabled with a drb3. I wish I had one!
AWeik said:My truck idles at about 1200rpm on cold mornings (all 6 cyls) and holds the egt at approx. 400*. Is this normal? I know my brothers '00. 5'/DEE doesnt high idle. A Smarty was programmed for about 20 minutes once just to try it out. Did the smarty leave something or is this standard. This is my first winter with the truck.
i hope im not hyjacking. AFW
Bob Wagner said:no there is not. what is the problem? 3 cylinder program kicking in?
thanks
Cummins724 said:I only wish that I could enable mine..... I've tried everything & it just won't take. It won't 3 cyl. or high idle. I've asked on a few threads, but got no reply from other members. Any suggestions?
RickFox said:Is there any way to turn off the high idle feature? It is just too cold here...
Thanks,
Rick
C4gan said:Where are you located? Friends truck did not high idle so i installed the smarty on 7, run the truck around and returned it back to stock and now his high idle works. All the smarty does is enables it in your ecm.
Cummins724 said:I first borrowed a smarty from a fellow member..... then borrowed one from Bob for some more experimenting. I recently bought one of my own & after 3 programmers set at all settings... ... I am getting nothing. I think something may be wrong..... I've tried everything that I can think of. Its been below 0 this week at night & still nothing.
SNOKING said:Are you pulled in, it will not work if you have the truck pulled into 110V's. SNOKING
Cummins724 said:No it isn't plugged in when I tried it out ..... if this is what you meant.
