Lag with twins
Andrew, when the engine is at idle, there will be zero boost on or from either turbo. So when we want to accellerate and add fuel to the cumbustion chamber the first turbo will spool first and it will be on it's own, the big turbo won't have had time or the volume of exhaust pressure to start creating any boost.
So for off-idle turbo lag, it doesn't matter if we have a single or twin turbos, the engine needs boost to burn the fuel we are asking it to burn. And the smaller the turbo wheels and exhaust housing, the faster it will spin up. The compounding of boost comes later.
Once any turbo has started creating some boost, there is less smoke and vitually no lag to throttle input. There may be some difference between the spoolup time because of the mass of the wheels and shaft on a really big turbo compared to a little HY. But I am concerned about off idle lag in daily driving.
Currently once I'm on the freeway at 80mph, the boost gauge needle gets whiplash when I punch the throttle. [instant 45#boost] What I want at this time is to keep the EGT gauge from getting the same whiplash or kink when it hits the upper peg
There may be a bottleneck at the compressor side of the HY in a twin setup, since the compressor housing is rather small, but if it is fed say 15psi and can boost that to 45psi with several hundred degrees cooler output temp, then I think the egts will also be a lot lower. This is the net result I'm looking for: No more lag than now, but cooler upper end boost.
The Piers HX40 [in Muncie] was being spooled by an engine that was reving up to about 17-1800 rpm when the throttle was punched, compared to my 14-1500 rpm. [the difference in torque converters] Piers and several other folks have convinced me that this was the reason that the bigger turbo had less off idle lag than my HY 'Nasty Nine' turbo.
Well it is getting close the the time to quite talking about it and start cutting and welding. I'm not sure when I will get to it though. Life is far too hectic right now.
greg L
