Sutton,
That's good info. I'm jealous.
Lsfarm,
Twins obviously work at the sled track. No one can argue that after seeing it in person. But since you asked about the twins I had on my truck, NO. I wouldn't have done as well at the sled pull with MY twin setup because the engine was choked WAY down on boost and power. That's why I took them off so quickly. I have a lot of lag with my current (cam, turbo, converter) combination, but at least it makes good power at some point. I would have done better with an HX-40 and better yet with a bone stock HX-35. But the twins, I used, NO.
Remember with twins that you have to maintain a good pressure drop across each of the turbos for it to work well. If one turbo is VERY small than there will be a HUGE pressure drop across that turbo and the exhaust pressure left over will not be high enough to drive the second turbo. That's the problem I had and that's the problem I see with people wanting to use an HY for a twin setup.
As I do more of my own testing, I'll report what I find. Until then we can all dream on.
-Chris
Lsfarm,
-Chris
