Well, here we are again!
The ujoint pictured below is the factory joint that I just took out. My rear drive shaft was replaced the 1st time to the dealer under warranty. Then they replaced the ujoints again after that, making a total of 3 sets of factory joints within 75,000. When I first started feeling the shudder again, I tried to hold off by using a needle point and injecting grease under the seal. I bought 2 months that way, but I'm not putting the miles on my truck right now that I used to. Anyway, I finally broke down and started the task with three #351's in hand.
I'm still convinced that sticky joints cause way more shudders/vibrations than driveshaft alignment. There is just no possible way for a 2-piece driveshaft to lay in a rubber damper/carrier and stay balanced with sticky joints.
Disclaimer: not responsible for bad pics, LOL, I shoulda used the macro setting for these close-ups, but forgot
