Uh OH!! Whats wrong?
5th gear nut / engine RPM questions
Who has had big time engine problems with their 2001 24V?
Ok, I have the ABS and "brake" light on my dash lit. I also noticed that my speedo is not really working below 20mph. When I get above 20, it kinda slides up to speed.
According to the manual, the ABS and brake light come on when the system detects and error between speed sensors, and the brake light comes on when a pressure difference is detected in the brake system.
Since I have the speedo error, I am thinking my rear speed sensor (that is used for ABS and Speedo) is failing.
What do you guys think. It also is supposed to have set a code that I guess I have to get Jeff or someone to lift. Man I got to get a scan tool.
Scratch That
After my post, I notices a thread on the same topic. Think I will change the sensor.
I guess this is rear wheel speed sensor month. :eek:
Mind started doing that 2 weeks ago, maybe one of these days I will get around to changing the sensor. How many miles are you at when this occured? I am getting ready to roll over 100k in about 500 miles.
Morph.
I celebration of what DavidTD has nominated as "Rear Wheel Speed Sensor Month," mine just when out, too!
Is this an expensive part? Is is a DC only item?
Thanks.
