Vavle argument? Rack that one up with air filters and oil... .
If you look at an indy car or F1, you'll find 4 or 5 valves per jug. As they have to run through an RPM range.
If you look at Dragsters, like Pro Bikes, you'll find 2 valves per, even on Jap motored bikes that started life with four valves, but those engines opperate at HIGH RPMs and that's were they make power.
All things being equal, a road going diesel that doesn't rev all that hard is likely more efficient in a 4v configuration than an otherwise comparable 2v set up.
Hard to compare the Rams as other changes came into play with the advent of the 4v head, electronic engine management, etc.
Max
Max
