You could do a swap of the front axle.
The CAD setup actually cuts the axle tube and puts the disconnect collar and associated housing/linkage about halfway between the pumpkin and the passenger wheel. So reworking a non-CAD axle is not practical.
If you do swap axles, also needed is a vacuum switch that goes in the top of the transfer case, and the vacuum lines that connect the switch to the CAD actuator.
Alternately, you can put a cable in place of the vacuum switch/motor setup for more positive control. This is the approach I would take if doing a swap. You'd also get the ability to run in 2WD Lo with a cable - a good feature for backing up a heavy trailer.
With a disconnected axle, you still spin the wheel u-joints, axles and side gears inside the diff. But the driveshaft and ring/pinion gears don't spin unless the axle is engaged.
Bottom line - IMO if you don't want 2wd Lo, swapping the axles is not worth the gains.
