Update PDR cam w/PDR HX-40
Skyjacker coil springs - repaint?
Help me out with a backspacing question.
Diesel Thunder was the first dyno run with the PDR cam but before that I also installed a PDR modified HX-40 w/ 18. 5cm housing. The sweet thing about this combo is that with the cam it spools as quick as my modified PDR-35 w/16cm housing with a better mid and top end. loss of EGT's is noticeable and the driveability is exceptional. I also put a laser cut set of delivery valves in before dynoing (lots of fuel) I still run cooler than before The #'s I ran (500. 2 hp) were the highest to date for me and with the lowest EGT's(for my truck) to date
We also went to the drags I ran a 14. 4 @99. 7mph this is in a 7800lbs 4X4 w/3. 5"of lift and 35" tires and a 5spd (this time can be improved w/some driver training:p ) the impressive part about this is I made it almost through the 1/4 before hitting 1500 on the pyro (it was a cool eve aprox 65deg) the other few times I've drag raced I would hit 1500 about the 1/8 mile or a little after that and have to run the rest of the 1/4 with the pyro pinned or back out. With the current set up I'm not really lacking any fuel (the comment was made after I hit the 1/8 my truck could'nt be seen through the smoke:p ) so to actually run cooler w/more fuel and more hp I still can't find a down side to the PDR cam. I certainly will keep looking though.
Jason
Thanks Jason, your last thread on the PDR cam got lost in B. S. Man if you laying down those numbers with a single turbo and that kinda smoke that is impressive. Lets all get together and sell Piers out of cams:D
It's good to hear you finially got enough turbo :D
Sound like it's time for me to add a little more fuel myself.
Thanks for the up date and comgrats on the HP # thats alot better than it did in Calgary LOL
Enough turbo hmmmmm I don't know about that;) I have a lot more turbo than before but more fuel also:D Much more useable power I got a run with the valet switch on at 305. 7hp witch isn't bad but smokes a little even with that on :p oh well can't have every thing I'm acually trying a couple of things to try to burn the fuel so we'll see.
Jason
smoke rules
jason
your dyno run was way awesome at Diesel Thunder :)
I've been having a little trouble getting on your website lately, must be covered in soot...
KEarnst
The web site is fubar right now the guy that's supose to be fixing it:-{} has'nt been able as of yet :mad: If you have questions or what ever just pm me and I'll get back to you. Sorry for the PITA factor.
Jason
Jason, if your "web hosting editor" cannot un-fubar your webpage for you, give me a holler. My coworker's wife is pretty good at HTML and website work.
Vaughn
Thanks for the udate Jason! :D
You should be very happy as well as proud, that *****in' Ram of yours laid down VERY impressive numbers on the dyno!
John, have you seen the video yet I sent Rob? I have a couple great shots of Jason's truck at the track and on the dyno. Hopefully he'll post some clips soon. Jason I'll get a tape and run a copy off for you too and send it up there.
Vaughn
No Vaughn, I haven't seen the video yet. I was supposed to go over to Rob's last night and watch it... I was supposed to be there when Shelby was there too but...
I got busy with other things ( :( )
Vaughn
I have'nt seen any video as of yet Big Bob is supose to have a tape. I was hopeing to get a copy from you also I've got several guys that want to see Christian's run.
glad to here you're stock valve springs made the trip to 4K again, made me nervous just watching! very impressive 12 valve. Bob
