Well I've talked to all the big names.
Money hungries want me to 'rebuild' and invest (if you can call it that) in HD parts--billet shafts, more frictions, flex plates, billet servo, billet piston, solid 2nd gear strap, accumulator, etc.
I've been told straight up there isn't anything wrong with the 48RE. With only 30K miles it would be a waste to do a 'rebuild' with 2nd gear band, new/more direct and overdrive clutches, servo, piston, etc.
Suncoast told me: torque converter, valve body, laminated flex plate, and billet input shaft for the intended horse power. Sounds reasonable
Other info I've 'heard', flexplate and input probably won't fail unless your gettin' crazy.
I'm convinced (unless YOU tell me otherwise), for this SIMPLE transmission, I'll live a happy life with a $500 TCS (same design as DTT--89, 91%, etc. ) converter, $450 valve body (raise line pressure to around 175 psi for holding power), a 3. 8 ratio shift lever (to lower apply pressure to 2nd band), and that's about it.
Toss in around $500 to remove and install at a local shop and I save about $3-4000 depending on what 'Top End' company you go with. That's enough dough to remove and install the transmission 6-8 times IF you ever had probs.
Well needless to say, with the small fortune I'm saving, I just ordered a HTB2 Turbo from HTT and STILL have change to put toward an SRT-10 hood!
By the way, talked to Dave at Goerend Bros. transmission and he is a very informative/nice guy. He offers a LIFETIME! warrantied triple disk configuration converter with billet cover for $1200! You can upgrade to a '1020' sled puller stator for $400 which GETS THE POWER TO THE GROUND! It's a tight converter very efficient from what I gather. Says it will start the truck moving in a power brake at about 1750 rpm's.
I would love to run this converter more that anything, but at three times the cost of a TCS-DTT it's not a viable option for me at this time. Hell, I work for my money and I still have gauges, wheels, tires flares, subs, bed liner, FASS, injectors, hood, lift, etc. to worry about.
Morale of the story: Just say no to Performance Chips of Utah, err, I mean transmission upgrades aren't the end of the world and you don't have to take out a second mortage to cover the job. Hell I'd do the job myself, but hate crawling around under a vehicle without a truck lift.
Opinions please!!!!!!!!!!!!!!!!!1
