Urgent Need of Adaptor
C.b. Antenna
Good Sam "CSP" Program
Anyone ever seen a Commerical 7 Round Pin (truck) to RV 7 blade (trailer) adaptor? If so where can it be had and for how much? I have not had any luck finding one on the net so I think I'll be making one (aka jerryrigging one) Sunday to Fed-Ex out unless one of you can save me.
Thanks
-Matt
I think? those round ones are used on semis, you may want to check the truck stops or a local semi parts house, to see if they have an adapter .
cheers, Kevin
Last time I was at Uhaul I was amazed at the selection of towing adapters they had. This was the big Uhaul center - not one of the little franchises. Its been a little over 2 years, so I don't know if this info is still good. Good luck.
-Vic
seven pin
You should change one or the other. The pin type in my opinion is better ,but most use the blade. the ends would be cheaper and better :)
Thanks for the inputs... whats going on is I'm having my brother move one of my trailers, he said it was a 7 "pin" on his truck the trailer is blades... turns out his truck is 6 pin so no sweat made an adapter for that a while back just won't have the aux 12vdc...
Thanks again
-Matt
The 7 pin and 7 blade sockets are wired differently. The aux leads are in different locations. The 7 pin also has seperate t/s and stop light circuits.
