Originally posted by Bill Lins
Found that out the hard way.That's why I ordered the good seals from CPFF.
And the part number for that seal is??
Originally posted by jmadden
if I remember I'll take a picture of the seal tonight. When I did my replacement it was w/ a double lipped nitrile for $2. 50 from Bearings Inc. (Cummins Npower sourced it for me)... 17k later no leaks!
jm
Originally posted by RDHamill
Does anyone know if there is a problem when removing the Vac/PS assembly from the engine. I'm wondering if there might be a concern regarding the gears that drive it and the injection pump. I'd hate to fix an oil leak and end up messing up my pump timing .
thanks
Originally posted by RJ2
Where does the leak show up?
w cummings :
the leak appears to be from the area between the vac and ps pump when viewed from under the truck.
I've cleaned the entire area a couple of times and even hung a clean cloth in the area, the oil always returns to this area.
My concern with the gears was the the injectioon pump gear might turn when the vac/ps pump is out, so my question is 2 part, could it turn ( as long as you didn't try) and if it were to turn some, would this effect the injection pump and engine timing?
thanks for the reply.
Rick![]()
