esamuelson said:If you do this could this improve your gas mileage on a truck running empty and not towing? In a sense you would limit the power and fuel of the truck. I guess it would be the same result as driving with the boost gauge and keeping your boost low. Maybe a bad idea but just a thought I had.
KingS said:does anyone have a picture of the valves your have used and other items involved thanks
KingS said:alright thanks where did you guys get yours at?
JStieger said:Anybody have a picture of the PDR valet switch?
Is it just a fancy electric solenoid valve?
Can it be set to open/close easily for certain pressures?
Cooker said:I can get a pic if you would like.
Yes it is just an electronic solenoid valve.
It is not variable like a hobbs switch, it is on or off.
As far as a wastegate mod you are probably thinking of a hobbs switch.
JStieger said:Little off topic...
Anybody have a picture of the PDR valet switch? Is it just a fancy electric solenoid valve? Can it be set to open/close easily for certain pressures? I remember reading on here somewhere that a person could use this for an electronic wastegate controller. If so, I sense another winter project coming along for my (3rd gen)...
