PeterT said:CATCRACKER,
Yes, the turbo is controlled by its own electronic unit. The signals that are required to run the turbo were easily attained from the Six-Gun wiring harness, so what you saw on the show was a simple interface to the Six-Gun, but the controller could easily be set up to capture that information from other sources.
Peter Treydte
Banks Power
Peter, thank you for the info. Since the turbo is controled by its own unit, are there plans to make this work on mechanically fueled engine like mine? I'm thinking that you might be able to capture enough information from some sensors already in place. (TPS, crank position, RPM, etc)
