Engine/Transmission (1998.5 - 2002) Vent fuel system
2nd Gen Non-Engine/Transmission suspension normal?
My fuel pressure line from the schrader valve vibrated loose and I lost the prime. Never had any problem before when I changed filter, but had a horrible time getting air out this time and getting it started. Fortunately it quit on me in the garage when I got home from work.
My old '90 was easy to vent, whats the best way on the '02? The injector lines are a lot different, but look like they are easy to 'crack'.
:( :confused:
You got it, crack open the 1,3,4,5 injector lines (those are the easiest) and bump the starter for a few cycles. (READ - bump the starter, then watch for fuel, not foam coming out from around the injector line nuts, then close them up)
Once you get good fuel coming out and closed up, the truck should start up, maybe a little rough, but it should start.
