For all those reading this: That dana 70 was rebuilt by 2 different shops 6 months apart at a total cost of $4000.Then I bought the truck, I was shown the reciept that the dana 70 is rebuilt. 2 1/2 years later since the rebuild, the pinion nut came loose. when I tried tightening back up, I found that I could not get the nut torqued to 220 ft/lbs as the pinion couldn't move anymore. It was jammed tight which tells me there are no shims inside for proper preload. #@$%!
The DANA 70 and 80 both use shims to preload the pinion bearings. If the pinion nut backs off it doesn't take long to trash the shims. Then theres no way to set the preload without a rebuild.
