Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Vibration with EZ box!!
ESPAR install question
I have had the EZ installed for about a week now. I have noticed a very noticable vibration eminating from the turbo area when the box kicks in the extra fueling.
The box is set at the max fueling, the elbow is installed, seeing 27 psi max, and around 1100 deg when towing a 5500# trailer up a 8% grade in overdrive at 65mph. The power is great, infact I can break loose the rear tires on the paint lines at intersections when taking off wit trailer in tow. I have a Jarding 4" pipe and bosch 275's installed.
The vibration shakes the whole cab and is present either towing or not. Has anybody else had this vibration or any ideas on what it may be? I dont want to introduce a vibration of this magnitude into a rotating mass spinning at 40,000 RPM or so, I dont think the bearings will take it?
I have also noticed that the truck seems to buck forward and back or sort of miss a little bit when towing like things are just not in sync, kind of stumbling. Any body else have this same thing going on>
2001 WHITE 2500 QC, LB, 3:54, 4x4, ETC/5-SPEED, HD TRANSFER, FACTORY FOG'S, MOPAR MUDFLAPS, AUTOMETER ULTRA-LITE PYRO & BOOST, BOSCH 275'S, K&N IN STOCK BOX, SILENCER RING AOL, JARDINE 4" IRRIGATION PIPE, BFG 285/75/16 ALL TA'S ON EAGLE SERIES 58, ICS NERFS, ARMA TUFF SPRAYED BED, LOOKING FOR AN EZ FIX. 16000 MILE SINCE JUNE ****POLARIS 700 RMK RULES THE HILLS****
any possibility of a cluth problem??
Could you have a fuel transfer pump failing???
[This message has been edited by JNutter (edited 11-25-2000). ]
I have the same vibration sometimes ans I don;t know if it the clutch slipping or just adding to much power too quick at low RPM's or what but I don't like it.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, 4w ABS, camper and trailer tow packages, HD transfer case, snow plow prep, group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, 4" JRE exhaust, BD exhaust brake. 22500 miles as of 11/11/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
Here's an idea (not that I think it's the cause)... ... . remove the Edge EZ and see if the problem still exists.
Please keep us posted.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s/DD Boost Module, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & mod. trans. frt. pump, BD VB & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
Recycle Bin: Prime-Loc fuel filter relocation kit (JUNK!), Bosch 275s & VA CPC (upgraded to DD3s... WOW! what a difference!), '00 Dodge/Cummins valve cover (changed my mind... stay tuned)
[This message has been edited by John (edited 11-26-2000). ]
Do you guys have any more noise (combustion clatter) than without the PE, like some have posted? Maybe your timing is too advanced for the heavy-hitting settings with a loaded rig scenario. I was talking with someone about the EZ yesterday and they believed the advanced timing is fixed at one setting and doesn't vary with changing conditions and boost--I don't know if this is true or not. I do know towing with a box set at max is NOT a good idea, I've heard that mentioned a number of times #ad
Vaughn
Is the vibration really bad in 4th gear around 1300rpm. If so all the boxes do that if you really lug down on the motor in the lower rpm,s. (mainly in 4th gear)The noise is coming from the transmission.
Hey sport bike, glad to see you're back.
I have driven many different enhanced Rams that have exhibited vibration in the drivetrain when you bury the throttle... ... . that were automatics. As others on this BB have stated, I believe it is the rear driveshaft center bearing support assembly.
<font color=blue>Two different things going on here. 700RMK has the EZ Edge and Douglas Hatfield has the "Standard" PowerEdge. Just wanted to make that clear that not both of them have the same "box".
Just wanted to point that out. <font size=-2>
[This message has been edited by KatDiesel (edited 11-26-2000). ]
Well the tests are complete and here is the result:
With the box not installed (boost sensor left plugged in so check engine light does not appear) no vibration, good acceleration with 24 PSI max, no trailer in tow.
With the box installed (fuel level-max) very bad vibration at 1300 to about 1800 RPM, fast acceleration, 27 PSI max, no trailer in tow.
With the box installed (fuel level-med) NO VIBRATION, extra fueling begins at about 1800 as near as I can tell, excellent if not better acceleration than max fueling, 25 PSI max, no trailer in tow.
With the box installed (fuel level-low) NO VIBRATION, extra fueling (it was hard to tell the difference between Medium setting) around 1800 RPM, again around 25 psi max. no trailer in tow.
Conclusion:
With the box installed at max, it is adding fueling around 1300 RPM. With MY setup of 285 tires, 3:54 gears and having the 275 injectors installed it is to much torque for the transmission at this RPM, in other words im lugging the transmission in a very bad way, hence the bad vibration just like if you would lug it in a normal way, lugging before would only happen below 1000 RPM with say 260HP and 520ft/lb, now with say 320HP and 640ft/lb the lugging rpm increases by alot. Does this make sense? With the medium setting it gets the RPM up before adding fuel and gets me above the lugging point of my setup, no vibration.
As far as the jerkyness of the vehicle in max fueling I feel it is the same, the rpm at 55mph is right at the fuel add RPM area so the box may get a little confused and cause a lugging, or add, no add, add type of event. This went away in the medium and low setting, getting above the new lugging RPM!
Sorry for the long post. Just thought it may help explain what I think is happening with my particular vehicle and help others with the same problems.
So for now I will leave the setting at the lowest setting and see how it pulls the trailer this upcomming saturday. I will keep you informed.
Also a note for those that want to change the setting in the box.
Be very carfull when removing the little jumper, it may be glued the the circut board and the jumper wires, I have destroyed (just the jumper)mine getting it off, will have to get another one to make things safe. Be patient and pry it just a little with a small screwdriver to try and loosen it before yanking on it with a pair of needle nose pliers.
700RMK
[This message has been edited by 700RMK (edited 11-26-2000). ]
Thanks 700RMK, your explanation sounds reasonable and lowered my anxiety level. My EZ should be here in a few days and the last thing I wanted to hear is that it would cause my ETH to self-destruct in some fashion. I'll look forward to your towing report as that is the reason I'm getting one.
Im going to remove the EZ and see if it still does its little vibration thing, it does it around the 1500 rpm level and at the same time the boost guage moves very fast towards the 27psi. It is in all gears, except first, and I really notice it in 3rd gear.
I have noticed a reduction in combustion noise, the engine is quieter with the box installed.
I havnt noticed any rpm change with out mph increase, so I am not sure that the clutch is slipping, I guess I could have a lift pump prob, going to have to get some guages for a pressure test. Any ideas on guages for this, dont want to install full time just check.
I will let you guys know later today what my test show on removing the box, after I remove I will change settings to the middle fueling and see if that makes a change on the vibration.
Thanks to all for your input!!
RMK
I figure the vibration was me lugging the transmission also as it usaully occurs with the PE in level 2 and 3 and appling heavy throttle in 6th gear at 1500 rpm so I don't put my foot in it anymore until its above 2000 rpms as the vibration don't happen at that rpm.
I have had a noisy transmission since I installed the dual disc. It is very noticeable in 4th at 1500~1900. Conclusion, don't lug the engine-
Thanks Kat! #ad
Hey HVAC nice shot of one BAD @$& TRUCK!! I was getting a little worried myself as EZ was going to be my stocking stuffer to the best person I know ME! After reading, no worries.
99 Dodge 4x4 Quad Diesel auto. K&N, 4" JRE, 5" chrome tip, matched 275 Bosch injectors, 2. 5" Skyjacker leveling kit, Silencer ring MIA. (more to come)
700RMK, My truck did the same thing when I added 370 HP injectors before move my torque plate back to the stock position. It was the clutch slipping causing the vibration.
[This message has been edited by drawson (edited 11-28-2000). ]
Well guys I towed the trailer tonight (flat freeway) taking the sleds to get worked on, the vibration is slightly noticable at the top end of the added fuel curve. At the lowest setting.
This may be a normal thing with boxes after reading other posts.
It may also be the long stroke these motors have and the fact they only have 6 pipes pounding, it could mean we can really feel every stroke when they are turned up!
I talked to Brett today in Ogden, (MR. PE)he invited me to come up and show him what I mean about the vibration, he dropped a new jumper in the mail,(great customer service) and then the cool part, he invited me to put the little white rocket on his new dyno!!! Twist my arm why dont ya.
Yes im going to do it, just have to find time to get up that direction. I wonder if he snowmobiles??
700RMK
Hi Gang,
Maybe I'm a little late here. Intresting discussion... I think I'm the only one
(outside cummins) that knows exactly how the ECM timing works.
Vaughn MacKenzie sez:
snip.
No, it's not true, the timing has no fixed setting it varies with RPM/Fuel/Boost.
You guys with a AT can hear this easily.
Have you ever noticed that the engine makes less noise once you're in OD? Than higher the boost climbs then less noise.
The ECM retards the timing with boost.
That's why the engine makes less noise at higher RPM under boost. Than more boost/Rpm
than more retardet.
The ECM timing works exactly like a gasser unit would. No fixed timing like the P-7100.
The "vibration" you feel COULD be overadvanced timing for that RPM/Boost level.
Another thought.
The ECM does not relate the timing to the engine temperature. This means that the timing remains the same even with a cold engine. It's over advanced until the engine warms up...
Have fun.
Marco
Well I did my test run on saturday.
I hooked up the trailer and headed to Strawberry Res. to go cut a Christmas tree, headed up daniels canyon, im not sure of the grade but long and steep, anyway with the box set in the middle fuel setting it pulled the trailer over the top in cruise control at 65MPH!! The max exaust temp was 1150 and I saw a constant 27 PSI boost.
Very slight vibration noticed at stop light take offs, but lots of black smoke!!
I did notice a jumping forward and back on level ground, kind of missing, or studder with the trailer on. I dont know what this is, to much advance or something else.
Im planning on leaving the box installed and the fuel setting in the middle.
These are my results of the PE EZ box. I am planning on going in to Edge Products shop this Wed for a dyno run. I will let you know of the results.
We need more snow!!!!
700RMK
700RMK, did you get your dyno results? I've been following this a bit since I have the EZ. Boy does that thing ever add to the fun factor in driving these things. I haven't tried any other settings but the stock setting yet.
Late '01 2500 2WD, QC, LB, Cummins HO 6 Sp. , SLT/Sport, 3. 54 Open Diff, Tow & Camper Packages, PowerEdge EZ w/elbow.
