Well the 02 is in the shop with a dead Injection Pump and Lift Pump. The truck has 35,000 miles on it and in like new condition inside and out.
The Dodge service dept wanted to replace the block mounted LP with the in tank coversion. I said no way!!! We all know of the short comings of this "repair".
The Dealer called the "Zone Rep" today and they are going to replace the VP under warranty. Current in effect warranies are the original 7/70,000-100,000 and the "Factory Extended Warranty".
How ever since I refused to get the in tank conversion they are going to charge me labor to install an OEM Cummins Relacement LP that I am suppling. After reading all the horror stories over the years here and at DTR I thought it would't happen to me.
Well now that it has happened to me all I want is a fuel system reaired as the truck was purchased so I can take the preventative measures to prevent future problems with a Walbro Pump from Glacier Diesel Power. Any thing that happens to the VP once this repair is done will be on me.
I'm sure it's been done before but as soon as I get the truck out of the shop I'm going to file a complaint with the NHTSA. Here is where you can too:
NHTSA Link.
It's pretty bad when you have to take it upon yourself to ensure the lack of problems down the road. It's the same thing I did when the truck only had approx 9,000 miles on it; ATS Triple Lock, Valve Body, and Controller. It was neccasary to do because of Slide in Camper that was going to be used. Even within the vehicles GVW rating the factory TC would not last. A lesson learned by my 1st CTD with slide in Camper.
Sorry for the long post had to vent.
NHTSA Link.
