Details here: TDR Privileges
Pulled out onto a main road friday night getting on it a little it acted just like if you broke a throttle cable went right to idle. Idled for a little bit, the throttle would make no diffrence then quit. checked the codes this is what I have.
p0237
p1689
p1688
po382 I have looked them up seems like the pump ? thanks for the
I had the scan tool hooked up and can see the pedal is working goes from 0 to 100 % I will try resetting it the truck will not start although it did start a couple of times and ran very ruff with no throttle response
