Bluechip Diesel's Injection Pumps
Yes, I purchased a Special X injection pump from Bluechip diesel. Curt Fisher is a very knowledgable man, and HE KNOWS those Vp44's !
Follow the instructions exactly !
I also purchased the plastic plate, that replaces the aluminum cover on the pump. This will pierce the wire in the exact location, so "If" something happens, you will be able to return it, because you didn't cut into the power wire.
Also, if you get the plastic cover plate, purchase the Torx plus 25 bit. TAKE NOTE: it is a 5 point, NOT a 6 point like a standard Torx bit, Additionally it has the hole in it, as the Torx screw has a pin in the center of the head.
Look on spending about $2,000 for I. P. , plastic cover plate and Torx bit.
Good Luck,
Peter
