Engine/Transmission (1998.5 - 2002) VP44,Play It Again
2nd Gen Non-Engine/Transmission Cold Idle
I was hoping for some info. from someone with more fuel injection experience than my self. My personal opinion is that the VP44 & it's type was never meant to pump 4500 psi. This is a cheaper pump & I believe that is why it was used. Couldn't an electronic coupling have been put in front of the P7100 to vary the timing for emissions? All the old axial piston pumps fed 2000 lb cracking pressure injectors & these were stone reliable. I don't believe the VP44 was, again, meant to operate at 4500 lbs. I do not know the system pressure of the old VE pump. If it is low could these injectors be used in the 2nd Gen? A VP operating at 2000 psi could probably be put in your will. A good operating catalyst will do wonders if emissions into the cat. are some higher. I'm not concerned about slightly higher emissions anyway, I doubt the EPA is losing sleep over failed VP44 pumps. Is it possible to change the VP44 into a low pressure injection system? What injectors? I understand the VP44 keeps getting better & better. It is never going to be a 500,000 mile pump though, as it should be. I realise mechanical failures are only one part of the VP's problems, I think the electronics can be sorted out much more easily than the rotor seizing & internal breakage. Thanks for any help, Randy
It is my impression that the vast majority of vp failures have nothing to do with the primary mechanical mechanism (the high-pressure part of the pump). I think there are a lot of electronic failures, ruptured diaphrams, failed timing mechanisms, etc. , but relatively few gross machanical failures. Again, my impression from reading over the years.
Who knows how long the main pump would last if the rest of the stuff didn't fail.
In the Dodge 2000 Service manual, it has:
"Warning: The injection pump supplies high-pressure fuel of up to approximately 1200,000 kPa (17,400 PSI) to each individual injector thought the high-pressure lines" (page 14-75)
some of these pumps may not last ,however mine is a very early 98. 5 now with 435960 kms on the original vp-44,expect it to go at least 500,000kms.
