Engine/Transmission (1998.5 - 2002) VP44 R&R question
Engine/Transmission (1994 - 1998) stuck universal joint
2nd Gen Non-Engine/Transmission Heater Control not working Help
Is there any reason, other than to make it a PITA to reach the rear injectors, to replace the rear engine hoist bracket? Do those bolt holes go anywhere critical? Couldn't I just put the bracket in my tool box in case I ever need to pull the engine?
I don't recall any sealant on the threads of mine when I did my own VP-44 swap, and used a couple of washers to make up for the thickness of the hoist loop and reinstalled to bolts, and did as you suggest - left the loop off but saved it just in case...
I would. Save the old one as a spare. I hear they are a pain to get to with the pump installed. By the way it is a cam position sensor.
Dave
DMannon said:
While I've got the pump out, should I replace the Crank Position Sensor?
That's one of those "let your conscience be your guide" - or "Warm and fuzzy feeling" sort of things. If you're certain the existing one is OK, why swap it out? On the other hand, they're a first class %&*%$ to swap with the VP-44 in place...
Do the bolts have to go back in? I thought I read somewhere that the installer left them out too? I hope they dont have to go back in, I didnt put mine in.
Only thing about leaving the holes empty, is the crud that will collect in them in case you DO need to get the bolts back in - and besides, the bolts are no obstacle to getting to the back injector anyway...
