I finally got mine in yesterday. Noticeable improvement, but I also did a big line installation. Here are some initial results.
Idle = 15 psi ----> 16 psi
Hi-Way = 13 psi ----> 15 psi
WOT = 3 psi ---->11 psi
My installation got complicated because I wanted to have two pumps on board. In my case all the failures and to many years in the Power Plants (Navy) so the "Installed Spare" concept bolts right up in my brain. The primary is a (going to be - not quite done yet) Walbro GS391 in conjunction with a Mallory 4307M regulator. The back up is the OEM Carter.
At this time I only have the Carter working. I still need to install the modified wiring to support the Walbro. The only down side I found so far is that the Carter is a very noisy pump. When it is hard mounted to the frame and sits right under the drivers seat you hear it all the time. I need to sound mount the thing in rubber grommets.
Here is a picture of the Draw Straw installed in the tank:
The Walbro and the regulator are not tubed in yet in this picture. I have completed the tubing, if any one is interested I will take another snapshot. The blue thing is an inline fuel filter. Here is a picture of my new mess:
FWIW my upper (return) screen was pretty dirty. From what I could tell this screen has no effect on the draw tube suction and is removed when the Draw Straw is installed. Here is the picture:
Jim
Jim
