W-350 Dually Top Speed
Winter mileage
Getrag Again, Clutch also
My club cab seems to top out max at 70-75 with a 5-speed, 3. 54's, and 235 77 tires. I don't have a tach, and know that the 5. 9l tops out 2500, but what is everyone else getting. And YES I know that this should be Fast enough, and it is but a little more would be nice. My truck just seems to be soooo wound up at these speeds.
Thanks,
Russell
1992 W-350 Club Cab Dually (All quiet for now)
1992 W-350 8' contractors dump with 3. 5"BD exhaust, 16cm^2 housing
i think it s/b more, i have 93 4x4 3. 54
duelly can do 3000 rpm had up to 80
and quit was still increasing strong,
is it bombed?
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
I have a rear axle ratio of 3:54 and LT235/85
tires on the rear. Don't have the tachometer
installed yet,but I have seen a 100 MPH more than once and the truck was not toped out...
my nerve was!
my truck see signature tops out at 92 mph going on level ground. it is turning about 2800rpms. I have reached 95 once going over and overpass with a slight downhill. This weekend i pulled a trailer with 3 snowmobiles. and all our gear, not to mention i am in winter mod with 500#'s of sand bags. the truck would go about 88mph on level ground. I think your truck should go much faster.
93 D250 5sp 3. 54 gears sans muffler, ISSPRO tach, K&N filter, needs to be bombed BAD
I would rather be cummin than stroken
I've always wondered the same thing. My truck will do about 85 or so. I would think that it would go faster, but I don't know. I've had my tach in for probably 6 months or more, but it still isn't working! However, the petal was to the metal when I was tryin' for the top speed. I've got 3. 54 gears, and 215/85 tires.
'93 D350 2wd Club Cab 5-speed,144,000 miles,K&N,Amsoil throughout,Borgeson Steering Shaft,Isspro gauges(Tach,EGT,Boost,Engine Oil Temp. ),16cm Turbo Housing, "My Dream Exhaust"(5" Chrome Stack)
I can only get 87mph in 5th with 4. 10's and 35's
88 GMC CREW CAB 4X4 89 6BT,NO INTERCOOLER YET,AUTO METER LIQUID FILLED GAUGES,NV4500,NP205,4. 10's,35 BFGA/TKO,6" LIFT,DETROIT LOCKER,16CM,K&N,3. 5 EXHAUST,BD "PRINCE OF DARKNESS"INJECTORS 96 215 hp on the way. J. Mason
Russell,
Is your speedometer correct? If it is, sounds like the top end on a 4. 10 truck.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft, JRE 3" exhaust, Banks Intercooler, Lucas injectors
I don't think my speedo is off because when it reads 70, it makes sense, I keep-up with traffic in 65 zones fine. Under the hood it says that my truck has limited slip and 3. 54's. I am thinking that my governor might be out of adjustment. I thought I was having a problem with the injection pump earlier, but that turned out to be sensors. My other truck is so heavy that it takes a while to get it to these speeds, but my club cab is floored to do 75 may be it has aftermarket gears? I don't have a clue.
Your linkage could be out of adjustment. Meaning when you have the pedal to the floor, you aren't really getting full throttle.
Thanks Matt S, I'll try to compare both of my trucks and see what I come up with.
I had mine at 155+ km/h (93 mph) on the weekend. It had some room left but was almost there. I have no tach but I do have a shiny new speedo sender.
91. 5 CTD 4X4, 5" Stacks, Tweaked Pump, 33" Boots (in the summer), One Wheel Squeel
unclebilly, what size tires do you have? I know that is just not possiable with my truck, with this problem at least. I don't know what am going to end up doing I can't make sense of it.
Right now I'm running stock sized tires (Yoko Super Digger V's) and they are new - I'll check what size they are tomorrow.
My tires are new 265 75 R16's, Yokohama SuperDigger V's.
I'm not sure if my govenor has been played with, the previuos owner mentioned that the pump had been tweaked - and I beleive it.
I know she'll do 100 but that would be about it.
