klaybus said:Walbro 392 Pump, install kit, & Fleetguard strainer went in the mail today. Have a few misc. parts that I should be receiving hopefully by Friday (Secret Squirrel Stuff) . With any luck, I should be "Walbroized" by the end of the weekend!
Clay![]()
Tomeygun said:Secret Squirrel Stuff? DO TELL!!!! I wouldnt mind messing with my walbro some more :-laf
I get a little joy from making it work harded and still holding 30psi![]()
Tomeygun said:My FP road to where I am now:
Stock:
Obviously sucks - gotta go!
Then to a DPP 95 "Fass2" pump only :
Good in the beginning, held 20psi for quite a while, then it ate a few brushes (keep in mind this has been fixed with newer units). Some new brushes in and all was good... . Until I started to bump the HP up. It started to get gawd-awful loud, and some dyno testing showed at 500hp it would draw from 21psi down to less then 8psi at full rpm.
So then comes the DPP 150 "Fass2" pump only:
At first is was SUPER quiet, that lasted about one month. The HP felt about the same, maybe a little more on top end due to holding more PSI to the CP3 inlet... Some further dyno testing showed no increase in power over the 95gph unit, and I could still pull the 150 down to 13psi from 21psi.
In comes the Walbro GL-392:
2 trys at the shims and I am sitting on 30 psi to the CP3 inlet. The install? Super simple. I have not a chance to the get exact direct comparisons on the dyno, but the truck FEELS at least 20-30 hp more on top end.
The main thing is the lack of the noise, I mean less than a church mouse - Seriously qiuet, and I really like that. As well I like that I can carry a $120 extra pump and swap it in on the side of the road in about 5 minutes...
I loved my DPP FASS2 fuel pumps, But I'll be keeping my walbro from now on.
dsherman said:You will not see any HP Gain and if you do its because you had a bad LP.
I know this I tested the Preporator 135A and the Air Dog and we did not see any HP gain, So if you do you are kidding your self :-laf :-laf
We dynoed two trucks and no HP gain with the 135A. My psi is 14 and towing a toy box up a pass it will pull down to 12psi empty it will not pull down on wot.
Can any one tell me the Volume it puts outNot psi.
Some one needs to bench test one I would, but got turn down![]()
Keep posting your Results here.![]()
lmills said:Who's regulator are you running?
DavidC said:clay
I am not an expert with this but I would think the regulator would only allow a preset amount of fuel pressure thru at all times. Where a bypass only opens at a preset pop off when pressure exceeds the pop off it opens. Where did you put the regulator?. I am guessing that the regulator is always returning to the tank where the bypass valve would not. Clear as mud?.
Dave
F8LDOSE said:Anybody using this Walbro pump on a 12 valve to feed the mech. lift pump?
DavidC said:I don't think you want to go there. Why add a headache to a mechanical system.
Dave
