Rear rotors are bolted to the hubs on the back side, you have to remove the hub to change rotors. When the hub is removed the seal will likely be compromised so a new hub seal is in the parts list. It the parking brake shoes or hardware are anywhere near worn or hardware is starting to look bad rebuild it also or it will have to come apart and do it all over.
Front rotors are bolted down UNDER the wheel adapter, you must unbolt the adapter to remove the front rotor.
Nothing "slips" off a DRW HD truck, everything is bolted on so it doesn't "slip" off going down the road under a load.
