Waste Gate ?
Defueling problem
I can't believe it.
Desperado
I have thougth of dissableing the waste gate. What I was wanrdering (sp) is has anyone had that experince and if so what could be expeced? Could it make to much boost for the engine, wouldn't want to hurt my BABY!!
95 Ram 2500 slight ENHANCEMENTS!! DEAD CAT, Boost and EGT gauge set, 5 SP, 4x4 trans filter from geno's
Yes you could fry your engine at higher rpm/speed plus a few other things you don't want to spend your money on.
Adjusting it would be better or bigger exhuast housing. I believe the 16 cm doesn't have wastegate but not sure.
Our turbo's have smaller air tunnel which gives the engine more boost at lower rpm/speeds but to much boost at higher rpm/speed without wastegate.
Check the archives or TDR magazines should have plenty of info.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
Disabling mine sure didn't hurt anything. With the 340hp plate & 5000' elevation, I got 32psi & 38psi @ sea level, so I left it disabled. #ad
Got to love these things. #ad
Money Sink - 96, 5 speed, TST 380, HX40-16, 300 HP Injectors, Scourge BD 4200rpm Governor kit, McLeod, 4", CATless, straight out back, chrome turn down, ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Mag-Hytec, 3:54, Michelin 235s on Alcoas, Rancho 9000's, Valentine One, Garmin.
Dutchmen 27' 5th Wheel.
GoldWing.
I disabled the waste-gate on my motorhome once. Darn think started dumping sewage every time I flushed the toilet so I enabled it again. #ad
Ohhhh... THAT waste gate!! Never mind... .
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
I did run around for quite sometime without one. I have only floored a couple of times. I did hit 30 psi. The turbo is fairly restrictive so running to much boost will probably cause a lot of back pressure. Could blow a gasket or etc. This is of course with the cam plate forward. If you are completely stock you should be safe.
YOU ARE YOUR OWN WARENTY STATION !
I just put a new waste gate on that illflem gave me. I backed the rod off some. I push about 22 psi. I gonna the next time I work on the truck will try to adjust for 25 to 27 psi.
95 Dodge Ram reg cab,2500,5spd,Tweaked & Peaked Cummins Diesel, MODS, K/N filter,dual exhaust 5'' tips,Lost muffler,turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges. Shell Rotella in pan. Fleatgaurd filters. 140k. on the OD.
If you can smell this message. I Farted
I ran mine dissconected and wired shut for over 100k with out any problems whatsoever. 43 to 53 psi. I had it so it would bleed off to 45psi by pinching the end of the steel hose and cutting a slot behind that. nees very little flow through the pinced end and usually bout 1/4 way through the cut. at 372hp.
mainly, keep a close eye on your egt.
97' 2500, 2x2, 5spd. tst#10,afc springkit,silencer ring & kitty missing, straight pipe
Hey Jeff... . Disable your wastegate again please!!! I think I smell your message.
'98 reg cab 12v, 5-sp
