Topzide
I was wondering how this works? Is it a continuity type sensor that when water is detected, it passes signal like a closed switch? Was looking at adding to my filtering on my transfer tank to help with water detection. Was thinking if it worked that way, could pass a ground which would light an LED on dash to alert me to issue or am I over thinking this and just keep using a water block filter? This was going to work along with the water block filter to help with the filtration for the truck fuel and tractors. All fuel for the truck goes through the transfer tank before needing in truck. Just want extra level of filtration for truck and for tractors. Thanks in advance for the help.
