Water Leak from driver side sun visor
A/C conpressor clutch coil
2wd vs 4wd. 4wd suspension issues?
My truck is a 2004 Dodge Ram Quad Cab 2500 with the Cummins 5. 9 4x4 .
I went thru the car wash Saturday and Sunday it was raining here and noticed a drop of water on the steering wheel .
So I looked up and saw water on the part that holds the sun visor in place.
Has any body ever had this happen ?
Do you think it's the Windshield or the Marker Lights ?
Thanks
Jim
-- email address removed --
Many of us has had the same problem, including myself. It is the clearance light that is leaking. There is a TSB for it.
I want to Thanks You Guys for the info .
And were can I find the (TSB) ?
And what did you guys do to fix this problem ?
Jim
I took mine apart and found that there are little plastic sealing washers on the screws that hold the lights on that are prone to crack causing the leak. I had two cracked on the passenger side and I would get a few drops of water coming down the passenger side sun visor holding clip.
I replaced them with small rubber o-rings and a little clear silicon, havent had a leak since!
Thank You for that information I will take them apart this weekend.
Thanks alot
Jim
