Water pressure max??
Truck and trailer mods - 1st tow
Where's a good place to mount my Prodigy in my 3rd Gen?
When i purchase the Cedar Creek I went thru the same issues (low water pressure) I called Forest River, told them the issue they informed me of the built in regulator. Call the dealer or Keystone. You have a great trailer and i would be surprised if you did not have a built in reg.
Now that you know how your pressure should be, run it without the regulator if it is the same, don't worry about it. If is a lot stronger then you should look deeper into it.
Jim
Water Pressure Max
I have had a Sure Flow smart senser 5. 7 pump on my 04 RV for four years it is said to make 65# pressure. Have had no trouble with water pipes. Never used a pressure regulator. on this rig. This may have been a problem on the real old RV's bu i would not worry on the newer one's.
You guys with water pressure trouble. If you use a water filter try removing the cartridge and try it. some cartridges are to fine.
