Yes, I put a Van Aaken box on it when it was about a month old. It's worked flawlessly since. I think it's a Van Aaken C3.2 or something like that. For the most part, I have just left it on 50% forever, changing it only now and then to impress someone.Van Aaken box on a 2003? My friend's Van Aaken box on his '99 is 23 years old now. Great product.
Thanks! I have none of those issues. I was told that hard starting was a symptom, but my truck will start within a few revolutions down to zero degrees with no preheat.Hanging idle, no throttle input idling up, Injector knocking, Leaking tips causing white smoke on cold start, Excessive smoking or smoke where there wasn't during acceleration or cruising. Just a few off the top.
Think you have an issue?
I guess I should look out toward the exhaust pipe when I start it — I would think there would be a big cloud of smoke if there were fuel sitting on top of a piston.
I know how you feel, sometimes I get up in the middle of the night and shine a flash light under my truck to check for leaks given all the gaskets and seals I've replaced. Proud to say I have zero leaks of any fluid for now.Maybe I'm just paranoid and off my rocker or something?
The ones you buy now are way better then the ones the truck came with from factory.
Partnumber was superceded by Bosch a couple times. Ours came more or less with first Gen CDI injectors, and Bosch made them better through the years. Got that info from Martin at BBi. First Gens we were happy to see 200k Lifetime, nowadays 500k+ seems to be reachable easily.
