LightmanE300 said:
Interesting point. Our stations were sampled once a month for 4 months, for the reasons you listed a few times.
If the results were consistent from test to test you could probably say with reasonable certainty that you are getting consistent fuel quality. I was under the impression that you only did two tests, for a total investment of $100. Part of my opinion is also based on a TDR article by Bill Carson I read before I bought my truck and joined the TDR. In fact, it was one of the "free" articles found on the web. In regards to cetane, I don't recall ever seeing any place other than Shell advertising "premium" diesel, which is one reason I am going by the Carson article:
https://www.turbodieselregister.com/mixing_gasoline_and_diesel.htm
"Diesel at the pump can be found in two CN ranges: 40-46 for regular diesel, and 45-50 for premium. The minimum CN at the pump is supposed to be 45. The legal minimum cetane rating for #1 and #2 diesel is 40. Most diesel fuel leaves the refinery with a CN of around 42. The CN rating depends on the crude oil the fuel was refined from. It varies so much from tanker to tanker that a consistent CN rating is almost impossible. "
I admit, for the reason quoted above that I am assuming I am getting close to 45 cetane wherever I fill up. I also assume that every major fuel stop is adding their own blend of additives when they fill their tanks.
Truckers generally don't know much about fuel, other than where to get the cheapest stuff that moves in a lot of volume.
That may be true, but the reason I choose high volume fuel stations is because of the freshness factor. Fuel delivered to a low-volume dealer that does a lot of maintenence can still degrade in quality if it sits in the storage tank. That's why no matter where you buy your fuel you should save the receipts and document your fill-ups. And being a regular customer increases your chances of satisfying recourse should you get a bad tank of fuel.
Fuel analysis testing has proven that a busy station doesn't always ensure good fuel. There are many, many factors from transport to tank maintenance to bottom water draining intervals, etc.
I agree. That's why I believe that if you test the fuel you should test it on a regular basis. That same article also includes the quality of crude oil in the equation, which is something that can vary at any station, at any time.
For the record Crunch, I'm not saying that your fuel is good or bad, just that you really don't know how it is - other than you dont have a problem using it and get good mpg. If all you've ever run is 40 cetane fuel and your engine 'sounds good' to you, do you know any better?
That's where regular monitoring of the fuel filter(s) come into play. I've been replacing my fuel filter every 10,000 miles, and I've never noticed a build up of crud, or pulled any noticable water out of the fuel. The oil still looks good after each 5000 mile oil change, and I don't recall ever seeing any black smoke coming from the tail pipe. It's these kind of consistent patterns that lead me to believe the fuel quality is also consistent, regardless of the quality at purchase. I also try not to let the tank get too low, in order to keep any sludge in my tank (or variance in fuel quality from purchase to purchase) from passing through the engine in any significant concentration.
The bottom line is that if your truck runs fine on the diesel you're using, you really don't NEED to do anything about it. If youre picky and want the best fuel out there for your truck, lab testing is the way to find it.
I think the fuel discussions can play out a lot like the oil discussions. If you change your oil and filter every 3000 miles it probably doesn't make any difference which oil you use. Likewise, if you monitor engine performance and change out the fuel filter on a regular basis it probably doesn't matter where you buy fuel, as long as they meet minimum requirements and you don't get a bad tank because of some intervening reason. I keep a spare fuel filter in the truck for that purpose, but fortunately I've never had to use it.
Here's a thought regarding the testing of fuel. The members of the various diesel truck groups (TDR, TDS, etc. ) in cities or regions across the country could establish their own testing group. Members could contribute a few bucks to a fund, establish a rotation among agreed upon fuel stations and select members could do the sampling and send them in for testing. Those results could be made available on the web sites to the subscribers in the diesel groups. I'm not likely to spend $50 on a regular basis to test the fuel of the several dozen stations in my area, but I would donate to a fund that others also helped to maintain.
